voldemort
voldemort
Filters: 649
I dont know if its because Im running ff off a thumb drive using parallels or not but ocassionaly of late I will make a filter that in editor view renders fast but when i close the editor the preview window either never renders it or takes 5-10 minutes ???? any Ideas what could be causing this?
Thanks for any help if you need additional info please let me know beyond toilet flush several of the ones I submitted yester day respond similarly
Today I was putting the final polish on my matrix code filter and it refuses to render it --no errors just nothing yet in editor view the result renders fine
I even waited 45min to see if it was just being sluggins but it isnt that
voldemort
voldemort
Filters: 649
This is the file in question I realize its quite large and complex but after 45 min you would atleast think it would start rendering
considering all the component windows will update with a reasonable time frame includeing result Im just at a loss I have had filters way larger with far more demanding components that rendered faster
again thanks
The matrix n1v.ffxml
voldemort
voldemort
Filters: 649
okay this is weird I deleted the resume file and rebooted the vm and it works now but it waits 3-5 min before it starts rendering and then it zips right through it --looks like its a vm related error instead of ff
it's not you or your machine, volde. it's the filter. there are at least 32, 5 color gradients in there. i also think i counted 4 tiles components, a TON of offsets and profile gradients, blends and others. it's a HUGE filter. it took over 5 minutes for me to see the first block of results and over 12 minutes to finish and i cut it short before it did and opened the editor on it.
and by the way to the filter maker on this one, 30 of those 5 color gradients can be removed and not lose a single function or effect in the filter.
voldemort
voldemort
Filters: 649
Point well taken --I submitted it with intent to twek it in the future for one thing the glow isnt right charecters could be tweaked more etc
thanks for the reply
ah, it was your filter. lol. ok. i removed those 30, 5 color grads. it's still super slow smile:(
30 unregistered users.
