Luca Tunz
LucaTunz
I've got this error when i try to submit...what it is ?
From my understanding it means you need to add at least one unique user control to your filter.
*The built in controls (Size, Variation, and Tiling) don't count.
Top
Filter Forge, Inc.
Yes, uberzev, you are right.
There is a number of simple checks for filters submitted to Filter Library. We hope this will make filters in Filter Library more useful and user-friendly.
aylien
I dont get whats meant by Control components... how and what im i supposed to add?
EDIT: i get it now
Quasimondo
Quasimondo
Filters: 32
I also just came across this warning and I think it doesn't make sense. Not every filter does necessarly need controls. For some it might just be sufficient if they have the standard pixel size and variation sliders.
I also have another problem now that I cannot submit a filter because it contains a warning sign - the thing is that the filter works just fine and it needs that special kind of setup (in this case a float slider control in a int input) in order to work comfortably. And - it is a warning - not an error after all. So I vote that this limitation goes away.
Hmmm... why can't you just remove the warning? It shows recommendations on how to remove it -- have you tried these recommendations?
If you have a special case when the recommendations don't help, can you please describe the case here?
Quasimondo
Quasimondo
Filters: 32
The only way to remove the warning is to replace the normal slider with an intSlider. But in my case that slider is needed for two different inputs - one goes into a float input and the other one goes into an int.
For something like that it would be interesting to have something like a converter component which does float->int / int/float.
The whole Slider/intSlider business is confusing to me. There should just be one slider that does it all.
Quasimondo
Quasimondo
Filters: 32
Additional the remapping option of intSliders is rather strange. I found this "step" thing pretty unusable until now. Especially since as factors that you can enter there only integers are allowed.
One additional option I would need there is an offset. I also don't appreciate the automatic limiting of the allowed values. The error checking for out-of-range values should happen within the components and not by limiting the inputs - but maybe you implemented it like this for performance reasons.
kenmo
Here is Kenmo
Creating filters in Filter Forge is a nightmware and not very user friendly. I too am getting this error and scratching my head on how to resolve the error "No Control Components".
Is there not a simple user how to on how to create filters?
Totally disappointed & very confused....
Small block Chevys never die...
33,857 Registered Users
+44 new in year!
101 unregistered users.
