If I'm work on ff at midnight as the date changes say one in 5 night the program crashes an error report generated but when I try sending it say web brower can not be opened . Relaunching program works perfectly except as you would expect unsaved work is lost. Not a big problem but I thought I would let you know.
Also I've noticed when you copy components which include a curve into another filter the curve isn't working correctly - a simple unpluging and re plugin fixes the problem........ Carl
Interesting observation -- we'll definitely look into it.
Hey carl smile:) I would suggest frequently backing up the "My Filters" folder in the Filter Forge folder on your computer.....just in case it decides to 0-byte you in the butt again.....and especially after finishing any work that would be hard to re-create.....
Vladimir smile:)
Hi StevieJ, I learned the hard way early in my betta testing time, after loosing filters into the etha to save under derivative names regularly, sometimes filters having a dozen saves smile:| some one has already suggested sub-folders and being able to change to lists........... look forward to it....... cheers Carl
Yeah, being able to use other folders would be nice to catagorize (My Filters, Filters in progress, backups, etc.).....instead of only having one with everything in it. Currently, I name things in an alphabetical way so they are all together in the list.....like "Metal1", "Metal1Test", "Metal1Variation" ect.....so I don't have to search up and down the list to find things.....
33,857 Registered Users
+44 new in year!
100 unregistered users.
