Checker component...
Connected to motion blur... (radius*: .00000001, directional: 100, angle: 0)
*Note that ANY radius value over 0, ANY angle, and gaussian turned on or off will still produce this problem.
Motion Blur Bug.ffxml
ssamm
Filters: 21
I've also noticed that the Blur component also wraps around (or blurs with the other side of the image). (If that is what you're pointing out.) I was going to mention this as a bug, but then thought maybe it was intentional because FF was so big on seemless tiling...
(But in any case, it would be nice to have an option for non-wrap-around blur...)
That's a different issue ssamm.
ssamm
Filters: 21
Okay, sorry. But what specifically are you saying should happen vs shouldn't happen here? (And why?)
Based on the settings entered there should be no discernable change from the original image.
ssamm
Filters: 21
Ahh, I see what you mean. There is an anomaly line when directional is set to 100 (where it should look more similar to when it is set to 99.99 or something).
Yes, definitely looks like a bug. We'll look into it.
19 unregistered users.
