chrom
Hi,
there are many errors:
Many missing pictures for filters and presets.
Output format button not clickable (gray).
Some outputfiles are named png some jpg; opening jpg in viewer says wrong extension it is png.
crash durings tasks. Is there somewhere a logfile?
Cpu percentage setting does not work (set to 70% but use 90%).
for some search-strings search filter does not work. Empty result for existing search-string.
This is by design. Visual Batch Renderer is not intended to render thumbnails. You are expected to wait until thumbnails are rendered in Filter Forge, then add the filters from FF to VBR.
it would be from my point of view to help GMM and FF team to help you that you could explain more in detail and depth what exactly is happening and how to be able to reproduce and test the errors you are showing so is more easily to identify and solve it
I mean for example, to tell what you do to get it, what do you expect, and what happens
so, please would be great if you can explain more about the errors you are having
thanks
33,857 Registered Users
+44 new in year!
15 unregistered users.
