David Roberson
Artist
Filters: 37
These blocks with the square grid of pixels show up occasionally in my filters. In this case it might be an issue with a Map Script, but I've seen it with some Math components, too. If this is a common problem, what debugging steps should I try?
Sorry that I do not know what may be the source of the square grid of pixels, BUT I can help to try to find what may be wrong.
What is important is to tell what FF version you are using, if it is the same with different render resolutions.
There could be different reasons why this may be happening. What I do when something weird happens there are some things you can do
OPTION 1 - Go to the FF options and preferences and see if there is something that you have that may be the reason for this, maybe there is not antialiasing active, or is active with wrong setting, or something else
OPTION 2 - Another thing you can do is to render each one of the components of the filter and see and test if the problem appears,
1 - start testing fr om beginning of the filter components and stop when this effects you are telling may appear in the result
2 - when you find where is it, you must see what are the components involved in this result and what settings you have
3 - Try to use different settings to see if it continues or could be removed
4 - Try to use another way if possible
5 - If you can not find out yourself, Try to make it reproducible (how to get the wrong effect) and tell the steps to reach it, so we could help you here in the forum or you could upload the filter that shows the problem and see what it maybe
If the problem is inside the Math Script component, I do not have any experience in scripting, but you could try to see each of the lines of the script and see what each do, and if they could be the reason for the problem, and can test where in the script it happens. And also you can share the script here if other that know about scripting can help you
You can also put a thread in the FF scripting part of the forum for others to see with the script that gives the error
OPTION 3 - Maybe it could be a combination of things and not just only reason
OPTION 4 - If this may be a bug inside FF then you have to contact the FF team and be able that they can reproduce and see wh ere it fails.
Wish you best and that you can find what is wrong and fix it
David Roberson
Artist
Filters: 37
Yes. Since I wondered about antialiasing I did check those settings and increased the level a bit.
I also looked at each component, though in my case I went in reverse order by following the input chain. I have tracked it down to a map script each time, though the grid of pixels seems to come and go. I repeated this a few times to confirm that the problem is intermittent and occurs when a noise map script is fed into a distortion map script. Individually, these scripts have no issues. I think the problem relates to the increase of noise during distortion.
I have a pretty complex graph with multiple copies of four or five map scripts, and they are all essential, settings included. So, changing the settings isn't acceptable in practice. If I have time today, I will see if a simpler graph can reproduce the problem with a minimum number of components. I'll post that if it works.
Thanks for your advice!
33,857 Registered Users
+44 new in year!
18 unregistered users.
