STEPH08
I can't change the Temp folder easily. I must edit the Options.xml file.
>I like to place the Temp folders of the applications I often use under a RAM disk, to preserve the SSD disk which has a much more limited lifespan compared to a Hard Disk<
The problem with the xml edit is that as soon as I change something in the options or update the application, the default Temp location is reset (FF v12)
I hope you can fix. THX
33,792 Registered Users
+20 new in 30 days!
15,374 Topics
+48 new in year!
11 unregistered users.
