yveslafont
Hello,
I just update my working FilterForge 10 to the 11, under Win 7 64 bit, and the software don't run
No error message, just nothing happen.
Can i have some help about ?
Greetings,
Yves
Would help to know how you are running it. As a plugin with a graphics app or as a stand-alone program. What type of computer as in specs.
yveslafont
I use it as a stand-alone program.
My computer run on Windows 7 pro sp1 64 bit, intel i5, 8go ram, system on a ssd, and data on hd
Filterforge 10 run pefect...
Sadly... my 2 cents. Windows 7 is not supported for FF 11 (see the download page). This is not surprising given that MS no longer supports Windows 7.
I would say go back to version 10 and see if that works....Then install 11 with the install rather then the upgrade path.
See if 11 work that way.
yveslafont
Thank you very much for your fast and precise replies.
FF10 was still installed, when i installed FF11.
I didn't use the upgrade path in FF10, but the direct download from the website.
So, that is pity, i continue for now working with FF10.
Greetings,
Yves
GuyLau
I have exactly the same problem. (New v.11 installed separately).
Just won't start with Win 7 Ultimate SP1 x64 !
[Intel Core2Quad Q9550 2.83GHz - 8Go RAM - OS: SSD - Data: X-HDD]
(One of my Multimedia stations which works very well)
- Standalone: Nothing happens - No message.
- Plugin: Freeze Photoshop (64 Bit) - No message.
... and Filter Forge 10.008 Pro works well smile;)
Which component (Win 10) is missing ?
Filter Forge (.exe) has increased from 95MB (v.10) to 205MB (v.11) !
What's the trick ? smile:?:
"Simplicity is the ultimate sophistication" - Leonardo da Vinci
33,857 Registered Users
+44 new in year!
12 unregistered users.
