I was submitting an animated filter and the submit wizard would get to the point of rendering the presets....
It would get to the first preset and go slow then FF would crash right before it finishes rendering the first preset. There is no bug reporter or error dialog that appears FF just closes to the desktop. I started taken out and changing bits of the filter with the same results. Then I turned the filter from a SURFACE filter to a SIMPLE and had no issues submitting the filter...... So with this knowledge I created a very easy to render filter that should submit but this one also crashes FF during the submission process....Its just a profile grad turned into an animated surface filter.....Once you try to submit this filter the first preset should render slow and then the crash happens right before the second preset starts..... using the latest version of FF and windows10..... Test Submission.ffxml Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: January 11, 2022 8:03 am | ||
Once you open this filter it may not crash on the first submission try.....But once you have this filter in your "My Filters" folder just close FF and try to submit it again.....
it seems that when you first add this filter to your folder it struggles to submit but it does....... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: January 11, 2022 8:13 am | ||
Posts: 3505 |
Thank you CFandM, I forwarded the issue to the devs.
| Posted: January 12, 2022 7:55 am | ||
29 unregistered users.
