James Allen
Posts: 3 |
I should start by saying that I doubt this is a Filter Forge bug. I'm posting here primarily to see if others have experienced it and to discover if there might be some fix/workaround that I'm missing.
Is anyone else having problems with compatibility between Affinity Photo 1.9/1.10 and Filter Forge 9/10/11 on Windows 10? After a hiatus for most of 2021, I have recently returned to a project in which I was previously using Affinity Photo 1.8 and Filter Forge 10 without any issues. In the interim I updated Affinity Photo to 1.9 and more recently to 1.10. I now find that no selection information is passed from Affinity Photo to Filter Forge. Filter Forge works fine if the filter is applied to an entire layer, but does not work at all if there is a selection (the selected region does not appear in FF and the preview window is always blank). For my needs this renders the FF plugin useless, and Filter Forge is a key asset in my workflow. If I uninstall Photo 1.10 and instead install Photo 1.8, the two programs work together exactly as expected, with selections once again being honored. There are, however, two problems with this as a solution: - I have many files that I opened in Affinity Photo 1.9 or later, so they can no longer be opened in 1.8. - In the long term I definitely want to be able to update Affinity Photo to later versions. I discovered this thread on these forums: https://www.filterforge.com/forum/read...&TID=15412 It appears to be outdated, however, since Affinity Photo 1.8 and FF 10 work together without issue. Does this mean that Affinity Photo broke the interface again in 1.9? Or something else? Any insights anyone can offer would be much appreciated! FYI - I made a similar post on the Affinity Photo forums a few days ago, but the response has been underwhelming (i.e. none). |
| Posted: November 17, 2021 12:39 pm | ||||
Posts: 3505 |
James, welcome to the forums!
Right now we are in contact with Serif devs discussing the way to make FF officially compatible with AP. I don't know all the details but here is what I'm told: - There are two kinds of selection in AP: regular selection and smart object selection. Smart object selections are known to fail when passed to the plugin, Serif are looking into that. - Regular selections should work correctly in AP 1.10/FF 10. If you have issues with regular selections please make a video showing the issue and send it to the support team - we'll pass it to the Serif developers. |
| Posted: November 18, 2021 5:38 am | ||||
James Allen
Posts: 3 |
Thanks for the welcome and the response! As far as I can tell, the problem occurs even with regular selections. I have made a couple of videos to show the issue: 1) Single pixel layer, selection, filter: https://vimeo.com/647390146/3a1ac3dac3 2) Two pixel layers, Merge Visible, selection, filter: https://vimeo.com/647390462/a5631ea4ae The second video was made in response to a question from a moderator on the Affinity forums. That forum thread can be found here: https://forum.affinity.serif.com/index...ent-859297 It sounds like there is an awareness of the Affinity Photo and Filter Forge selection issue on the part of both team, and that is really good to discover. Hopefully a solution can be found to get these two excellent tools talking again soon! Thanks, James |
| Posted: November 18, 2021 12:38 pm | ||||
Posts: 3505 |
Thank you James, this is very helpful. I'll post here when I have any news on the matter.
| Posted: November 19, 2021 4:52 am | ||||
Posts: 3505 |
Here is the response from Serif. No comments from my side:
| Posted: November 22, 2021 4:56 am | ||||
James Allen
Posts: 3 |
Confirmed! A couple of quick tests indicates that this solves the problem for me. To clarify for anyone reading this going forward, change the following preference setting in the Affinity Photo main menu: Edit->Preferences->Performance->Hardware Acceleration: Enable OpenCL compute acceleration uncheck the checkbox control so that acceleration is not being performed. Restarting Affinity Photo is required for the change to take effect. I have no insight at this time what consequences for performance in Affinity Photo might ensue without this enabled. Hopefully the communication between AP and FF can be altered so that this acceleration option can be used. For now this allows me to get back to work. Thanks very much for following up on this! It's very much appreciated. |
| Posted: November 22, 2021 11:08 am | ||||
18 unregistered users.
