| Wile Beck |
Hello to all and a big SORRY for my bad english. My german is better^^
I have a new Laptop and now I have some problems with FF 9 +10. At some Filters the preview is completly different to the rendered image. I don't know what happens, on my old Laptop I haven't this problems. To show you what I mean, I attached a image. The used Filter in this case is Petrification. But the same problem I have with a handfull other Filters. Not all, only some filters are made it. Do you have any idea? Thanks for your help, Wile |
| Posted: March 14, 2021 1:40 pm | ||
Posts: 3505 |
Hi Wile!
To make your previews consistent with the final result, please make sure to disable the Draft mode and set View > Preview Size > Actual. |
| Posted: March 16, 2021 6:44 am | ||
| Wile Beck |
Thank's for your answer GMM, the Preview is Actual.
Some images I will render I get the correct result. My images are big (8000x8000), but some will be fine others are bad. I hope anyone can help me. THANK YOU! |
| Posted: March 16, 2021 4:04 pm | ||
Posts: 3505 |
Wile, do you save your image via the Save Image As button or via the File > Export command?
Also, what format are you saving to? Please try saving your image as TIFF instaed. |
| Posted: March 17, 2021 6:27 am | ||
| Wile Beck |
I save the image as PNG. When i try the export, i get the same result.
Perhaps it is my new computer? Now I have a AMD Ryzen 7, 8 core. With my old computer (Intel i5) i haven't these problems. |
| Posted: March 17, 2021 5:34 pm | ||
Is the seamless tiling activated or not?
I think that to be able to find what may be happening you would need to make a screenshot of the settings you are using with the result you get on the preview and then when you save it what do you get Have you changed any of the FF option in the menu? |
| Posted: March 19, 2021 7:05 am | ||
| Wile Beck |
Thanks to all!
I've installed FF new and now all is fine. So this post can be closed. |
| Posted: March 21, 2021 4:20 am | ||
