tekman
Mr
I am using FF10 as a plugin-in in Photoshop Elements 2021, Photoshop CC 2021, Affinity 1.9, and Photoshop 6. In all cases when requesting FF10 via the respective plug-in I initially get "filter forge is running-click here to switch". In fact there is not an instance 0f FF running, it does show in task manager (see attached). I am unable to use or exit from any of the host applications without invoking Task Manager. he following is the error I get after ending using task manager.
<class XFW::OSCallError> ::WriteFile(block 4, child pipe 0000000000016D8, master pipe 00000270A3226100) failed witherror code 0x00000E8: The pipe is being closed.
Additional information:
Edition Windows 10 Home
Version 20H2
Installed on ‎6/‎17/‎2020
OS build 19042.789
Experience Windows Feature Experience Pack 120.2212.551.0
Processor Intel® Core™ i7-9700 CPU @ 3.00GHz 3.00 GHz
Installed RAM 64.0 GB (63.8 GB usable)
System type 64-bit operating system, x64-based processor
Pen and touch Pen support
FF 10.005 Profeddional Edition
Build: 10.005.57698.9634 Release 12/23/2020 12:48
Photoshop 2021 Release 21.1.1
Photoshop Elements 2021 Release 19.0(20210126.m.155261) x64
Affinity Photo 1.9 Release 1.9.0.932
Photoshop 6 version 13.0 x64
Grosvenor
I’m having the same issue
tekman
Mr
i finally figured out my problem.
Try this, it worked for me.
Go to Tools -> Options -> Rendering -> uncheck "Use output dithering when saving non-project images"
I don't recall checking this option. A Default setting perhaps?
Larry
kathleenmadeline
kathleenmadeline
Hello!
How can I install Filter Forge (11) into Photoshop CC when I already have it as a plugin in Photoshop Elements on the same Windows computer?
I appreciate any help you can share.
Kathy
Kathy
kathleenmadeline
kathleenmadeline
I figured it out. I just downloaded again and installed in Photoshop CC.
Kathy
+12 new in 30 days!
