Borkus McJorkus
Filters: 15
Saw this in FF 9.007, and seeing it in FF 10.004. In these examples, I am running FF in standalone mode, though these behaviors also appear when using FF as a plugin.
The component snap-to-grid behavior has recently gotten imprecise. In FF 5, the top-right corners of the components snapped to the gridline intersections, and connection wires could follow a perfectly vertical line. Here's a screenshot fr om FF5:
Importing this filter from FF5 into FF9/10 results in the top-right corners of the components getting offset so that those corners are now halfway between two vertical gridlines, instead alongside only one. Also, the connection wires that had been drawn in perfectly vertical lines in FF5 are now very slightly diagonal in FF9/10.
Attempting to recreate this component structure reveals component behavior wh ere dropping components on the grid results in those components hopping several random gridlines away from the mouse cursor location - generally, no more than 3-5 gridlines horizontally, and 1-3 gridlines vertically, and always to the left of the cursor. Here's a screenshot of my attempt to duplicate the FF5 setup in FF10:
The 0.5 gridline offset could be seen as a minor annoyance. I like my vertical lines, and would miss them if they were gone forever, but I could deal with it. But the jittery, unpredictable behavior of component placement is a major problem that interferes with a clear organizational layout.
Perhaps this behavior might have something to do with my difficulty in working with groups in FF? Who knows?
¯\_(ツ)_/¯
=== tech info ===
Operating system: Windows 10 x64 Edition (10.0 build 19041)
Physical memory: 3747 MB
Number of processors: 4, available: 4
Processor info: AMD Ryzen 3 2200U with Radeon Vega Mobile Gfx, ~0 MHz
Filter Forge x64 10.004.57464.34066 Release
jitter bugs.ffxml
Thanks for your report - unfortunately we're unable to reproduce it.
What is your display resolution and Windows scaling factor?
Borkus McJorkus
Filters: 15
display resolution: 2560x1440
scaling factor: 225%
I'm using an HP laptop with an external monitor, if that's important.
33,857 Registered Users
+44 new in year!
13 unregistered users.
