Nickson
Posts: 8 |
Hi all,
Loving filterforge, just bought Pro as I was assuming my very low CPU usage while running slow filters was down to the non pro limitation of processor cores available to use. Even with pro it seems FF is using at most 12% of my CPU, very confused about why its not using any more, everythign is terribly terribly slow at this rate. My multithreading is set to use all availble CPU's/Cores I'm running an AMD 3950x, 16 core. Any help would be greatly appreciated! |
| Posted: July 18, 2020 9:28 am | ||||||||||||
Nickson
Posts: 8 |
| Posted: July 18, 2020 9:47 am | ||||||||||||
Nickson
Posts: 8 |
| Posted: July 18, 2020 10:52 am | ||||||||||||
Hello, Welcome to the forum
My big congratulations for being able to have and AMD 3950X 16 cores, with this surely would be much faster, but as you show it seems that it uses fully only some of the 32 cores Have you tested if other graphic software is able to use all 32 cores ? Maybe you can do a benchmark like for example "3D mark" or any other to see that the CPU is working correctly and how it should be Are all the cores enabled and working on Windows? as it seems that sometimes the cores need to be enabled manually How to fix disabled AMD Ryzen processor cores So then you if you have all the cores enabled and the benchmarks gives similar results to other similar AMD3950X, you can be sure that the problem is from FF software What kind of cooling for the CPU do you have? as this is a very powerful and hot CPU I think that if you show already that are using more than one core, is correctly activated the Use all available cores from the Tools menu options |
| Posted: July 18, 2020 2:58 pm | ||||||||||||
Nickson
Posts: 8 |
Heya SpaceRay, cheers for the input!
I regularly use the system at 100% CPU usage in other programs for rendering, encoding and various other tasks, currently rendering on blender with full utilisation, looks like FF is the odd one out here! Going to try reinstalling and hope that its just a glitch somewhere in the pipes... Have all CPU cores enabled in the settings there too, but runs at the same speed as when its clicked on using a single core. Weird! |
| Posted: July 18, 2020 7:21 pm | ||||||||||||
Nickson
Posts: 8 |
Hey, so it seems that bomber isn't multithreaded when it has a particle loaded from a Color Control being driven from an image file
I've tested other functions which seem to utilise things properly, but the bomber node is stuck drawing absolutely none of my computers power as soon as it has an image texture loaded. Its not like it's using less of all cores, its only using 4 of the logical processors. I'm running the newest bomber node, and have tried Bomber+ too to no extra luck. Any thoughts? |
| Posted: July 19, 2020 4:44 am | ||||||||||||
Nickson
Posts: 8 |
I've been making lower resolution images to load into the bomber, but Color Control seems to upres everything I feed in, I can't get them to load at their smaller resolution to save computing power. Am I doing something wrong here or is this the only way to feed in external images
| Posted: July 19, 2020 5:24 am | ||||||||||||
| emme |
Hmm, sounds strange. From what I've seen, using bitmaps as particle source can be very inefficient - at least with large bitmaps, the rendering times can go up by 10x. I guess the sampling architecture just isn't very efficient with large bitmaps. However, I still get around 90% usage on all threads, when using image based particles... so sounds like you've got something weird going on there.
You should definitely be able to get better performance with smaller images - pretty much the same speed as with procedural components. The color control preview will upscale the image to fit your canvas resolution, but I think the bomber still only samples at the original resolution. At least the rendering speed suggest this. Try to find out if this behavior can be replicated anywhere else in FF. Let's hope this will get fixed. |
| Posted: July 19, 2020 10:06 am | ||||||||||||
Could you test the new FF 10 beta 1 and see if it happens the same thing? I think it would be the same, but there is no harm in trying it.
As you have tested it correctly that any other program works correctly with all the 32 cores, then it can thought that the problem or mistery is on the FF side. Thanks for making it clear.
I have no idea how the software uses and recognizes the multiple cores, but I suposse and think that most probably depends on the way the programming is made so the software can find all the cores. Maybe FF has been tested with 8 or 16 cores, but not with 32 cores, and there could be a possible bug perhaps, sorry that I do not know about this.
Do you mean that if you use big bitmap source image to be feed into the bomber it could be very inefficient? What is really "large bitmaps" from your point of view? Do you mean then that as the bomber particles are usually small, then you should feed small sized particles from source image, for example 500x500? |
| Posted: July 25, 2020 2:38 pm | ||||||||||||
Nickson
Posts: 8 |
Hi guys,
Apologies for the downtime here, had to focus on work for a while and couldn't spend time bugfixing here. I've tried the v10 beta and still have the same issues. I've also tried running my filters on my laptop and it fully engages the CPU to 100%. I can't see what is going on with the program that it doesn't seem to leverage a full AMD CPU. Its making it very unusable for my use case sadly. |
| Posted: September 22, 2020 1:06 pm | ||||||||||||
Great to have again news from you as I am interested to know more about this.
What is the CPU of the laptop? does it have more than 8 cores? Because FF surely works with up to 8 cores at 100%
So it may be perhaps in the way AMD CPU works and how is programmed and the way it uses the multiple cores? You have said that all the other software you have tried works correctly with all the 32 cores, so maybe the problem may be in the way FF is doing it, I do not know. it would be interesting to know if someone that may have a 32 cores Intel computer could test FF to see if it uses the whole 32 cores at 100% What graphic card do you have? One possible idea, could it be that the graphic card could be a bottleneck or making interference and hurting the CPU? I do not mean that the graphic card is a low quality or bad in any way, what I mean is the way that the software of the graphic card may be processing the data for the 32 cores, as I know that it has been told that some AMD graphic cards may give errors on some software. |
| Posted: September 22, 2020 1:10 pm | ||||||||||||
Nickson
Posts: 8 |
Many thanks for the replies SpaceRay, my rig has a 2080ti & a 1080ti which I regularly use for heavy 3D rendering without fault so wouldn't expect any issues/bottlenecks there. The laptop is 8 core, so would make sense that it is more supported by default.
Do the developers check these forums at all or do I need to go to them directly with issues? Thanks again, |
| Posted: September 23, 2020 9:53 am | ||||||||||||
| emme |
Is this an issue with the bomber specifically, or is it happening with FF in general? There are some pre-processing steps that are expected to not utilize all the cores, but that usually shouldn't take too long, unless you're working with very large resolutions.
| Posted: September 23, 2020 8:09 pm | ||||||||||||
I think this is a very important topic and is interesting to know more about this and you are fortunate to have a 32 core computer and thanks to you is possible to test really what FF can do and if there could be any possible bug or problem and I want to help you get the most of your amazing 32 cores CPU and so you can use fully FF
After having seen more information as detailed below here in the quotes I think I may help you to find a possinle way maybe to solve this It may be that the problem may be possibly and perhaps that you are not using filters that would need really the 32 cores so I suggest the following to be able to test it and have more information to find a solution to your problem INDEX POINT 1 - Use both Texture and Effects filters to make the test that make FF work much (i give some possible suggestions below) POINT 2 - Use high resolution results using Actual Preview size and NOT the reduced 600x600 preview, maybe use for example 5000x5000 POINT 3 - Test also the perfomance of FF and not only the amount of CPU cores used, I mean the time it takes a filter to finish POINT 4 - To be more clear of the possible difference it would be interesting and useful if you could be able to make the same tests in both your laptop and your 32 cores computer with the same filters and presets Thanks very much for making these test that I think would be helpful to be able to get more information about what may be happening and help you solve the problem and discover if the problem also help possibly to others that may buy a similar CPU and discover Here is a more detailed explanation of each point ---------------------------------------------------------------- P O I N T 1 --------------------------------------------------------------------------- 1 - As GMM told below amount of cores used depends very much on how complex and power the filter needs to work, so some filters may use little amount to process the result So here I suggest some complex filters that you can test as a possible example to make FF force use more cores Texture filters (these are self-generated and does not use any kind of bitmap imput or bomber) Terrain Generator by Orteil Effects Filters ( these are the ones wh ere you can use bitmap input and the bomber) Circular Reasoning by Rachel Duim with Preset 1 that includes dense packing and does not use bomber Will put more filters to test for you ----------------------------------------------------------------- P O I N T 2 ---------------------------------------------------------------------------- 2 - I think that an important thing to test it better and force to use more cores maybe and make FF work harder you can increase the output resolution to for example to 3000x3000 or even 5000x5000 or higher. Because if you test it with the default 600x600 it will not force FF to work much more And remember that some Effects filter that do load the source image from the main menu and not on a color control the final resolution is the one of that source image used ---------------------------------------------------------- P.O I N T 3 ---------------------------------------------------------------------------------- 3 - It would be really appreciated and useful if you could also take note of the time it takes to render the filter to test how much time it takes if you do not know how to show it, you need to go to the menu Tools ---> Options ---> Interface tab ---> Show elapsed rendering time (it is below the Multipass) Because is not only the cores that is important, as the perfomance of FF using those cores also needed to know and not only how much CPU and compare it with other computers or with ourselves. if you want I can make the same tests as you and compare them. ---------------------------------------------------------- P O I N T 4 ------------------------------------------------------------------------------------- 4 - As you have said that on the laptop works right or better I think it would be great to compare the results that you may get with the same filters and presets and that you test on your 32 cores computer and see what happens in your laptop and how they can compare to see if it may be a problem Please, Can you be so kind if possible to make the same tests that you make on your 32 cores that I suggested here, ALSO in your laptop to see really the difference between one CPU and the other? -------------------------------------------------------------------------------------------------------------------------------------------------- ------------------HERE ARE THE QUOTES I TOLD ABOVE ---------------------------------------------------------------------------------------- QUOTE 1
From seeing the graphic it seems that at least 6 cores are used but the others also has some minimal low activity, so is really not that they are not used at all. So I think that you can test some of the filters I put above on the detail of point 1 to really test how the cores are used QUOTE 2
So then if what GMM said is true, then it could be that the filters you may have tried are fast and does not need all the cores, so you should really try a filter that is very heavy in the CPU usage and so you could really test it if it increases the number of cores and the % of CPU See above on point 1 QUOTE 3
Question 3.1 So then is it a 8 core with 16 threads? Question 3.2 Is it Intel or AMD ? Question 3.3 As told above does the CPU of the same filter used in the 32 cores work better in the 8 cores than the 32 cores ( this is why I suggested point 4)
As far as I know the only ones that check these forums are the moderator GMM and Vladimir Golovin, as GMM is the one that tells the developers team about any possible problem or questions from any FF user
Good question, and Is true that to be able to know more about the possible problem is needed to test different kind of filters, and not only with bomber, see the point 1 above |
| Posted: September 26, 2020 2:09 pm | ||||||||||||
33,857 Registered Users
+44 new in year!
13 unregistered users.
