I was working on some filter that repeats numbers using a bomber, and I saw that reaching Repeat 60, something goes wrong. The numbers does not appear correctly.
I attach the filter. 7.ffxml |
| Posted: May 25, 2020 6:45 am | ||
| Posted: May 25, 2020 6:46 am | ||
| Posted: May 25, 2020 6:47 am | ||
| Posted: May 25, 2020 6:50 am | ||
| Posted: May 25, 2020 6:51 am | ||
| Posted: May 25, 2020 6:52 am | ||
The problem appears also without using the bomber.
Also the filter posted here by Mehmet Sensoy has similar results. Mosaic with 0 to 9 Numbers |
| Posted: May 25, 2020 7:26 am | ||
| emme |
This looks like a normal aliasing issue. It's to be expected when rendering small details with limited sample count. Try increasing your antialiasing samples and maybe use all pixels instead of edges only - that should fix it.
| Posted: May 25, 2020 8:52 am | ||
Thanks emme. You were right. Selecting All Pixels in the Anti-Aliasing worked.
Good to know it! |
| Posted: May 26, 2020 1:36 am | ||
