Filters: 705
I updated to 8.006 from 8.005.
The new version sometimes crashes without any error message.
Since yesterday it happened 3 times. One time after submitting a filter. Other two times while using the Editor. I had no other applications opened, and they were not particularly complex filters. Version 8.005 never crashed on the same filters.
Unfortunately, as I said, there is no error message or chance to report the problem. Filter Forge simply shuts down.
Filters: 705
Yes, the crashes continue. This time using the Editor, while connecting and disconnecting components.
Filters: 705
I'm still having crashes without error messages.
Apparently there is no connection with a particular action. These last two weeks, for example, I had no much time to use the editor, then I cannot do any comment about that. But I downloaded filters from the library and also, simply doing this, I got the same problem.
Sometimes I downloaded 2 or 3 filters. Everything looked fine.
Then, suddenly, after downloading a filter, FF just closes. The filter is correctly downloaded, but I must restart FF.
Other times, since the first downloading attempt, FF crashes.
As I said, because the filter that I was downloading works correctly, I can guess that FF crashes just after the filter is downloaded, not while doing it.
