Bookwormious
That is the message I get today no matter how I try to open Filter Forge. The message of course uses the full name instead of FF - I just tried to make the headline a bit shorter smile:)
But how do I get out of that loop?
It's fine, that the program is already running. But I can't access it neither as a standalone program or from inside Photoshop, as I normally can. This started earlier today, when I, as I also normally can, was downloading some new filters from FF's own page. I have rebooted the computer, but that didn't help.
Any and all advice will be much appreciated smile:)
That's correct: you can't run FF while it is already runnning.
It's possible you're too hasty. When quitting, FF needs a few seconds to close all handles: if you try to run it again before it's finished, you'll get the message it is still running.
In some cases the process may get stuck and will never close. You'll need to kill it via Task Manager to run again.
Bookwormious
Thanks a billion for answering me.
Yes, I might have been too hasty. Impatient. But the program stayed unresponsive until I rebooted the whole computer, and wouldn't open for me after that, because it was already running, so I don't know.
Just in case I wasn't too eager, where do I find that Task Manager, please?
The program can't be running after a reboot.
Please reboot and run Filter Forge before any other program, making sure you run it once.
I assume you're on Windows? You can invoke Task Manager by pressing Ctrl+Shift+Esc or by right-clicking an empty space on your taskbar.
Bookwormious
Thank you ever so much. I will try that, then.
33,857 Registered Users
+44 new in year!
100 unregistered users.
