KirkDunne
My problem is now solved but, for any future trouble-shooters, here is the story.
I have Filter Forge versions; 2, 5, 6 & 7 installed on my computer and they all work perfectly.
I installed Filter Forge version 8 (8.003 and later 8.004) (on the same computer) and when I tried to open/execute the program, absolutely nothing would happen. No hourglass, it wouldn't pop up in the Task Manager for even a second, etc, etc.
Yes, I tried every Compatibility option and no I am not running a Virtual Machine.
Let me say again; FF versions 2, 5, 6 & 7 continued to work perfectly this whole time, on the same exact machine (and for years before this).
After MUCH investigation and googling;
Turned out, my Windows Service named "Workstation" was Disabled. I enabled it and FF 8 now works perfectly.
So, I am posting this here just in case someone in the future has the similar, weird problem.
Windows 7 Home Premium 64-bit
(My OS and all my hardware have the latest/greates updates, etc)
www.kirkdunne.com
KirkDunne
"Workstation" Service
- Necessary to share files and printers with other computes within a network.
- "Creates and maintains client network connections to remote servers using the SMB protocol. If this service is stopped, these connections will be unavailable.
If this service is disabled, any services that explicitly depend on it will fail to start."
www.kirkdunne.com
Thank you for sharing your experience. It would be hard to figure that out from our side.
KirkDunne
Lol, I know, huh? That little quirk is a pretty unique software situation.
Glad to have found it and its solution.
www.kirkdunne.com
