Iron4Plankton
Hara's Crown
I am using FF version 6 on a Windows 10 computer with 8GB RAM. I can't exactly pinpoint a date when it started doing it, but when I try to use FF now it makes my computer "huff and puff" and sound like it is ready for takeoff.
I used to use FF on a little old Windows Vista laptop with no memory problems (it may have been version 4 or 5 back then). I don't remember having problems when I first started using FF6 on this computer.
I'm having some problems with other programs (such as Paintstorm Studio and Dynamic Auto Painter 5) also making the computer make noise. I think I have a dual solid-state and non-solid drives, or something like that.
Any guesses as to what is making FF use so many resources? Did one of the updates to Windows 10 cause problems with artwork programs?
Filter Forge is designed to consume CPU power. If you want to limit it, please select Tools > Options > Rendering > Use a single CPU/core.
[unofficial mode]
I am tempted to create a single thread where people complaining that FF uses too few resources and those who complain about using too many resources would argue with each other.
[/unofficial mode]
Iron4Plankton
Hara's Crown
Thank you. I switched the rendering mode and that seems to help.
Does the current version of FF use about the same amount of resources as version 6? There are certain programs that I regretfully haven't dared buy or upgrade to because it sounds like I need to get a 16GB or 32GB machine to run them, and that isn't in the works right now. (The new version of Dynamic Auto Painter and Topaz Studio's programs and a bunch of 3D rendering programs . . . sigh.)
emme
New in Filter Forge 9:
- Rendering speed has been reduced by 50% to save your precious CPU cycles!
- 64bit allowed users to use too much RAM, rolled back to 32bit!
haha... But it sounds like you just need a new CPU cooler (or perhaps the cooler needs some cleaning). That's what's making all the noise.
Version 6 came in two varieties: 32-bit and 64-bit. It would be incorrect to compare different architectures. But yes, FF 6 (64-bit) and FF 8 (64-bit only) consume the same amount of resources.
Oh, I completely forgot you can actually limit the amount of RAM consumed. It's another setting in the Tools > Options > Rendering window.
Still, it's not RAM that makes the noise, it's your CPU. emme is right: new cooler would probably solve your issue.
Iron4Plankton
Hara's Crown
My computer's "brains" are behind the screen -- I don't have a separate tower -- so I'm not sure if I can replace the cooler. (Actually, I know I can't; the question is whether someone else could!)
