jitspoe
Filters: 27
I wanted to make one of the controls behave in a discrete manner, so I figured, "I'll just use an IntSlider." Unfortunately, it didn't work right, as demonstrated by these screenshots:
jitspoe
Filters: 27
I think it's reading the integer value as a float somehow. Using a regular slider works fine, but it lets the user have non-discrete values (like 4.2 instead of 4 or 5).
Yeah, its not supposed to work right in certain situations. If you have a real world example your having trouble with I can probably figure out a workaround for you.
jitspoe
Filters: 27
I found a way to work around it. If I enable remapping and set the min and max value to the same as what's on the int slider, then it works.
20 unregistered users.
