Filters: 705
Before, when I opened a filter from the online library, FF opened it and the list of the filters also moved there. See my picture.
Filters: 705
Now it regularly open the filter, but the side menu with the filters doesn't go to the opened filter. I have to go searching it. Is it something bad in my FF settings and can be solved or is it a bug?
Please remove the following file:
%APPDATA%\Filter Forge 8\System\Positions.xml
and try again.
Filters: 705
Thank you GMM. I tried to do as you said, but I see no change.
Filters: 705
It is not a big problem anyway. Because scrolling up or down, I can find the filter highlighted. But just the menu doesn't go to the filter position automatically. I have to do it manually.
Filters: 705
Anybody having the same problem?
I'm afraid we're unable to reproduce it.
Filters: 705
Humm...
I tried to remove %APPDATA%\Filter Forge 8\System\Positions.xml
But no change. What else could be the reason?
15 unregistered users.
