Eplurbus
Eplurbus E. Unum
Hey fellow FF users, I am a newbie to FF, and I have a problem,....Since I installed the update for FF, the program will not complete any rendering. I never had this problem before the update. I use FF with Photoshop 2019 and Adobe Photoshop Elements. It gets to 99.9% complete and stops rending the filter. It does not matter the complexity of the filter or the size of the project. There is no error code(s). The host program whether PS 2019 or PSE locks up and must be restarted. FF did not do this until the update was installed.
Any ideas as to whats happening would really be appreciated. Thanks.
Eplurbus
Eplurbus E. Unum
I see no one else has had the same problem. Hmmmmmm. I have uninstalled PSP2019 and FF8.04 then re-installed them again. No changes. FF will not complete the render and switch the completed filter to PSP. If I go to processes, it does not show FF as a active process. If I go to users and close the running FF 8.04 it closes FF and transfers the completed rendered filter into PSP 2019. I give up ? what could it be? It's not PSP2019 because it does the same thing using Adobe Elements. Never did this with the last FF I was using. This only started with the newest release.
Myrrdraal
Myrrdraal
Filters: 91
I have the same trouble...
In fact the other night I fell asleep waiting and in the morning 7+ hours later it was STILL not done....just sitting at 98/99%
Today I discovered that I CAN save renders with it, however it WILL NOT complete a render of an image greater than 1024x1024.
I mean literally 1 pixel more and it gets stuck at 99%, I was able to duplicate this effect each time I tried it. The filter being used appears to have no effect on the render, it occurs with ALL filters.
I have had the issue occur both in standalone and plugin version.
~Myrrdraal~
There is a workaround:
https://filterforge.com/forum/read.php...&TID=16938
33,857 Registered Users
+44 new in year!
15 unregistered users.
