Janeway
Hello!
How can I move the default folder fr om C:\ to another HDD? (Wh ere FF7 storing downloaded filters, my filters, presets and a lot of other files.) I setting my default folders In my OS, before install FF7, but Filter Forge 7 doesn't care about it. I using Windows 10 Pro x64. I mean: I do not want: c:\Users\MY_NAME\AppData\Roaming\Filter Forge 7\ I want: f:\Users\MY_NAME\AppData\Roaming\Filter Forge 7\ |
| Posted: February 23, 2019 12:30 pm | ||
Posts: 3507 |
Hello Fuzfavesszo, please check this forum thread.
| Posted: February 25, 2019 6:06 am | ||
Janeway
GMM, Thank you, but it seems risky, I don't want to bother the other softwares, only Filter Forge is in the wrong place.
My Environments My Filters My Presets My Settings Search Index System ComponentDefaults.xml Favorites.xml FileFormatOptions.xml Options.xml Preferences.xml Recent.xml Search.xml These folders and files occupy more than 1.6 GB and will be even more. I do not like it on the drive along with the operating system. Not safe for my files. My work may be lost. It must often need to back up. It would be much easier and safer to set up an alternative path in Filter Forge settings. Previously, I solved this problem by using Filter Forge with software called Sandboxie, but FF7 doesn't start that way now, with Windows 10. Do you know Sandboxie? What can I do? |
| Posted: February 26, 2019 1:27 pm | ||
Posts: 3507 |
Sorry, no idea what Sandboxie is about.
If you need to back up the FF default folder, we have implemented a built-in backup tool in FF 8. |
| Posted: February 27, 2019 7:55 am | ||
Janeway
Thank you!
| Posted: February 27, 2019 8:17 am | ||
Janeway
| Posted: September 17, 2019 11:08 pm | ||
33,857 Registered Users
+44 new in year!
13 unregistered users.
