Anine
I just bought (finally!) FF7 and I get the error message:
<class XFW::ArgumentError> The handle 000000000013BDD0 is not a valid window handle.
It generates this as a bug report:
Operating system: Windows 8 x64 Edition (6.2 build 9200)
Physical memory: 8174 MB
Number of processors: 4, available: 4
Processor info: , ~0 MHz
Filter Forge x64 7.007.46686.60178 Release, February 13, 2018 11:09 [06-09-2018 13:43:32 Rom, sommertid]
Exception caught at thread 0000000000001A0C 'Application':
<unknown file>(0) : <unknown function>()+0 at 00000001400C3600 in C:\!D\Adobe\Plugins\Filter Forge 7\Bin\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 0000000140318DEE in C:\!D\Adobe\Plugins\Filter Forge 7\Bin\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 00000001403208A2 in C:\!D\Adobe\Plugins\Filter Forge 7\Bin\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 0000000140318566 in C:\!D\Adobe\Plugins\Filter Forge 7\Bin\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 0000000140318BF2 in C:\!D\Adobe\Plugins\Filter Forge 7\Bin\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 0000000140320CD4 in C:\!D\Adobe\Plugins\Filter Forge 7\Bin\Filter Forge x64.exe
<unknown file>(0) : <unknown function>()+0 at 00000001409A84A0 in C:\!D\Adobe\Plugins\Filter Forge 7\Bin\Filter Forge x64.exe
<unknown file>(0) : BaseThreadInitThunk()+20 at 00007FFB44AD3034 in C:\WINDOWS\System32\KERNEL32.DLL
<unknown file>(0) : RtlUserThreadStart()+33 at 00007FFB47331431 in C:\WINDOWS\SYSTEM32\ntdll.dll
CONTEXT_CONTROL: CS:RIP 0033:00007FFB4371A388, SS:RSP 002B:0000000000BF4360, FLAGS 0000000000000202
CONTEXT_INTEGER: RAX 0000000000000000, RBX 0000000000BF6220, RCX 0000000000000000, RDX 0000000000000000, RBP 0000000000BF4A10, RSI 0000000000BF6850, RDI 0000000000BF5170
CONTEXT_INTEGER: R8 0000000000000000, R9 0000000000000000, R10 0000000000000000, R11 0000000000000000, R12 0000000000BF44B8, R13 0000000000000000, R14 0000000000BF5788, R15 0000000000000000
So I looked around to see if I could find the solution and this is what I tried:
1. Go to the Filter Forge folder in the Plugins folder of your PS CS5.
2. Find the Filter Forge.config file.
3. Open the file.
4. In the IndependentUI line, if the value is false, change it manually to true.
5. Save the changes in the file and try running the Filter Forge plugin again -- this might help.
I also uninstalled and reinstalled it
I am using it as a filter with Adobe PS CS5
It works as stand alone.
I have been using FF3 up till now.
Funny thing is, in December last year, I downloaded the trail version of FF7 and used it for a while. Then the error message showed up and I thought it was because the 30 days was up, but I guess not.
Please help.
Anine
OMG I FIXED IT!
There were more than one Filter Forge.config file! OR it keept swapping back to FALSE
