Pumakitten
I was having some problems starting up filter forge. I kept on getting <class VFW::oscallerror>getwindowW(handle 0001033c)(control<class controls label<@026CE3D8)failed with error code ox00000002 the system cannot find the file specified.
When first installed, this is what I would get when I tried to open the stand alone. When I opened Photoshop CS2 and tried to open FF I would get Windows No Disk no disk in drive please insert disk. options were cancel try again and continue. I would have to hit continue 4 or 5 times to open up filter forge. Then when I tried to enter the key it would disappear. I deleted it and reinstalled. then I would get the above error with controls label <@01E4E3D8>. could not complete command because of a problem with the filter module interface. I uninstalled and reinstalled. I still have to click the continue 2 to 4 times before it opens, but I did get registered. (to anyone else its in help- about). Hope this helps with the final version.
onyXMaster
Filter Forge, Inc.
Hello!
Is it possible that you have your temporary files folder (specified TEMP and/or TMP environment variables) on a device that is currently not available?
We will include additional critical error handler in next beta release so the errors will be more specific, but maybe the problem is just with temp folder location?
33,857 Registered Users
+44 new in year!
16 unregistered users.
