Ozmandias
I got my new hard drive installed along with all major software. Installed my FF3 and registered it with my serial. Am using it standalone for now. It loads fine, I can apply a filter and save the image, however, when I click on "close", I'm getting this error message...
Filter Forge x86-SSE2.exe Application Error
The instruction at 0x00df121b referenced memory at 0x00000000b.
The memory could not be read. Click OK to terminate the program.
It doesn't seem to affect anything, but I thought I should check and see what it means.
(I went from WinXP to Win 8.1... 32-bit to 64-bit. Is that what's causing it?)
Thanks for any help/advice
Yep. FF3 was released in 2011 and is unaware of later Windows versions. It will work correctly with Windows of that era - XP, Vista and Windows 7. And it will still render images in later Windows versions, despite the error message on exit.
Ozmandias
Okay, I'll just ignore it. Thanks, GMM.
