IVSMA
IVSMA
Upgraded to PSP 2018 from X9. FF5 worked fine in X9 32bit & 64bit. Now it works fine in 2018 32bit but not 64bit. When going to launch from (PSP 2018 64bit) effects/plugin menu FF5 does not launch but PSP stays open and usable; all I get is the following error messages...
Message 01: <class XFW::ArgumentError> The handle 00FDAE20 is not a valid window handle.
Message 02: Plugin passed bad parameters
Bug report generated and sent just posting here incase someone has a solution quicker than support can get back to me! Thanks! smile:-)
FF5 was released in 2015 and is unaware of later host versions. You can use FF5 as a standalone program or under a supported host version:
https://www.filterforge.com/download/hosts-5-0.html
IVSMA
IVSMA
Thank you GMM... I have upgraded to FF6 now hoping for an update to support PSP 2018 sometime this month as suggest in an email response from your tech support team. smile:)
+12 new in 30 days!
