I've been getting FF shutdowns from <Class XFW::OSCallError> faults in accessing Temp/Filter Forge/.... log files. Mouse starts hanging up and becoming unresponsive before FF crashes. I have been creating the bug reports....which I assume are being automatically sent to FF. As a remedy, I've been running system's Disc Cleanup, CCleaner, and then restarting.... Runs fine for a while, then repeats the same failure....
Forwarded to the programmers.
Thanx.... Frequency is usually about every other day after running a while. It doesn't happen with any of my other programs, so I'm pretty sure it's FF and not my OS. I'm sure they will have it all worked out before release....
Did you send the automatic bug reports to us?
I believe that I do.... I hit the button that says "make bug report" and it doesn't tell me anything after that....so I'm assuming that FF is getting them. I was wondering if anyone else has encountered this problem? I've been reading, but haven't found anything.....
I was also thinking that FF might have a 'share' conflict with one of my other programs....which might account for it.......
PS....I've recently become hooked on your "Organics" filter smile:) Addictive....
Vladimir, Jitspoe is experiencing the same exact thing from the "Resource Leak" post....
