Faustyna
Faustyna
So I've had this weird glitch lately when I use filter-forge through photoshop as a plug-in. It only covers about 4/5ths of the picture, leaving a stripe on the right side.
If I use filter-forge alone it works fine, but not through photoshop. It was ok a few days ago and though. Anyone know how to fix this? Thank you!
You’re either using a selection (the filter is applied to the selected area) or your image is larger than the canvas (the filter is applied to the visible area). Please fix that, and everything should work well.
skisouth
Filters: 6
GMM is correct. Just went through this as a bug report and it was an apparent issue between image and canvas in photoshop. Select crop image in photoshop and crop image to canvas size. Cleared up the issue for me.
22 unregistered users.
