i just got a crash of FF. i had just made a new hdri lighting environment and it worked fine. no problem importing and no problem using this.
i had a number of programs open in windows, FF, paint shop pro 10, internet explorer, and windows explorer. so, i was using a LOT of windows resources.
after i created the new hdri, i made a screenshot of FF using the new environment and went into i.e. and posted this screenshot on the FF forums.
i went back into psp and set up a new image to import into the FF hdri import. i saved this and went into windows explorer and changed the file type (.jpg) to .exr.
i then made FF active again and hit 'import hdri' in the menu and got the attached bug report. i immediately took a screenshot of this, as sometimes the bug report generator doesnt work.
i then hit the 'generate report' button and got another error message. this one had more information in it than the last one, but i had already put one screenshot in the clipboard, so i didnt want to erase that with another. so, i just hit 'generate report' again and it failed to generate a report and crashed FF fully and crashed internet explorer fully.
also, i've noticed that when i REALLY tax my system and use a LOT of system resources, that FF will crash more frequently and not be able to generate a bug report. i suspect this has more to do with windows resource handling than with FF itself.
nonetheless, i'm attaching the one screenshot.
I've assigned this to the programmers.
Bella
Filter Forge, Inc.
Kraellin, please send us the Filter Forge .log file.
It's stored here: "C:\Documents and Settings\YOUR_USER_NAME\Local Settings\Temp" (to get there quickly, you can just type %Temp% in your browser address bar). The file is named "Filter Forge x86.log" or "Filter Forge x86-SSE2.log".
hi bella,
attached is the file you wanted. i peeked at it myself and there is one line in there i thought was interesting:
failed with error code 0x000005AA: Insufficient system resources exist to complete the requested service.
, which makes me think i had the right idea about what was going on. is there anything i can do on my end to help windows handle this situation better? i mean, other than having 4 programs open at the same time, two of which are working with image files constantly? is there some windows service or something i could turn on or off or add a file or remove a file or something?
i've actually had this happen a couple of times where i didnt report it because the browser wouldnt open to send the bug report and those few cases it was always a similar type crash; i'd have been working with large programs previous to working with FF or i had more than one program open at the same time, like psp usually.
in the early days of beta, i could almost always tell when FF was going to crash because it would start slowing down and the mouse would start to get a bit sticky and jump rather than scroll smoothly, but now i dont see that as much and so usually dont have much warning that this is going to happen.
so, is there anything, other than sending you folks bug reports, that i can do on my end to help alleviate this condition?
ok, the file wouldnt attach here. apparently a .log file isnt a valid format for uploading here. so, i made a copy in notepad and saved it as a .txt file.
hmmm, didnt like .txt files either. it's a small file, i'm printing it here:
Filter Forge x86-SSE2 1.006.3518.58018 Release-SSE2, November 30, 2006 10:46 [2/2/2007 5:23:55 PM Central Standard Time]
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x0000FC50 0x0002031C) for window 000B0258/000B0258, control: <class Controls::Panel>@023CF908.
[Controls::Control] Exception occured while processing window message 0x00000202(WM_LBUTTONUP) (0x00000000 0x0014002A) for window 0002031C/0002031C, control: <class Controls::Button>@0245FC50.
Exception caught at thread 00000C54 'Application':
<class XFW::OSCallError> ::CreateFileW(file 'C:\Documents and Settings\Someone\Application Data\Filter Forge\My Filters\Dark Framing 1g.ffxml') failed with error code 0x000005AA: Insufficient system resources exist to complete the requested service.
<unknown file>(0) : <unknown function>()+0 at 00697780 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00692E7D in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00550BED in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00558522 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 004B85F9 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0048CC15 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00489795 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0044E2E5 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0044EE43 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 004421AF in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0051B35F in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0050F454 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00519B84 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0051B6B6 in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0051083F in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 77D43A68 in C:\WINDOWS\system32\user32.dll
<unknown file>(0) : <unknown function>()+0 at 77D43B37 in C:\WINDOWS\system32\user32.dll
<unknown file>(0) : ReleaseDC()+298 at 77D4546B in C:\WINDOWS\system32\user32.dll
<unknown file>(0) : SendMessageW()+71 at 77D454CC in C:\WINDOWS\system32\user32.dll
<unknown file>(0) : Ordinal384()+51104 at 71981492 in C:\WINDOWS\WinSxS\X86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.10.0_x-ww_f7fb5805\COMCTL32.dll
<unknown file>(0) : IsWindowVisible()+128 at 77D45B40 in C:\WINDOWS\system32\user32.dll
<unknown file>(0) : CallWindowProcW()+25 at 77D45B5F in C:\WINDOWS\system32\user32.dll
<unknown file>(0) : <unknown function>()+0 at 0050F87E in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0051B2BC in C:\Program Files\Filter Forge\Bin\Filter Forge x86-SSE2.exe
<unknown file>(0) : GetMessageW()+293 at 77D43D91 in C:\WINDOWS\system32\user32.dll
<unknown file>(0) : DispatchMessageW()+11 at 77D43DF7 in C:\WINDOWS\system32\user32.dll
<unknown file>(0) : <unknown function>()+0 at 002C0022 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 001B:77E73887, SS:ESP 0023:0012C760, EBP 0012C7B4, FLAGS 00000206
CONTEXT_INTEGER: EAX 0012C764, EBX 04EDD430, ECX 00000000, EDX 00000000, ESI 0012C7F4, EDI 0012C7F4
CONTEXT_SEGMENTS: DS 0023, ES 0023, FS 003B, GS 0000
hmmm, that doesnt look very satisfactory. i suppose i better email this.
Bella
Filter Forge, Inc.
Thanks, Kraellin. This is in fact quite satisfactory. I'll disregard your email, if you don't mind smile;)
Now we know that this is the same error concerning "Insufficient system resources" that we've been dealing with for quite a long time. The bad news is that we are still in darkness about what causes it. smile:| Well, we'll be digging deeper smile:|
well, i got another one, bella. and no, i dont mind about the email. do you want me to post that same log file again for this new one? it's a similar thing about system resources but i think a different error number.
here's the screenshot and again, it didnt generate the browser to send the report.
this one occurred after FF had been sitting in the background for quite a while. i ran psp and was browsing in forums and so on. when i went back to FF and tried to scroll down the filter list i got the crash and bug report popup. there was no second popup this time.
here's the screenshot:
18 unregistered users.
