Filters: 711
Nested Loops seem to have some troubles in FF6. An example is Stacked Swirl : it doesn't work.
What FF version are you using? I was pretty sure it had been fixed in 6.006.
Filters: 711
Version 6.006 for Windows.
I also thought that this bug was solved. But two days ago another user wrote me saying that she could not use Stacked Swirl anymore. I was surprised and I went to try. She was right. I still get the error.
Filters: 711
Some screenshot
Filters: 711
Another
I am using the latest build.....Check the number and date build...I am using Windows7 x64 so perhaps its one of those Os specific things....Where it needs to be fixed on different systems....
Filters: 711
It could be. I use Windows 10. Could Windows 10 be the reason why it doesn't work? There are sometimes things that in Windows 10 must be set differently. There are also things that in Windows 10 don't work (I've already found two troubles in Windows 10. I contacted Microsoft and spoke with them. They only said that "Windows 10 is still under development and that they are aware of some trouble").
Heres my original post about this bug...Try the test filter in that thread and see if you get the same result.....My version of FF was released on Dec 29 2016 so there is a fix in that build....Looks like you have an early version without that fix yours is Dec 20....;.)
Nested Loop Bug
Filters: 711
I loaded your Nested Test. The result does not change. I get the same error.
Install the latest FF....Which is the Dec 29 build of FF...From your about box you have the build from the 20th....The one from the 29th has the bug fix....
Looks like it was a silent update... smile;) smile:)
Filters: 711
Then.....
There is something else not working.
There are at least three FF 6.006 versions.
December 20. I have. When I click on FF to check for updates, it says that it is up to date. But it is not true.
December 23. If you look here, it says that December 23 is the last version. But this is again not true.
December 29. You have it. Fr om what GMM says, we should download it from the download page. This is what we can guess after all this talk, but it is not explained elsewh ere.
The program should recognize if there is an update or not.
Or, at least, it should be clearly written in the news page.
Thanks CFandM. It works now.
The program should recognize if there is an update or not. Or, at least, it should be clearly written in the news page.
Cool... smile:)
In all these years I have only uodated by dowloading from the site...This way if I installed on a different computer that did not have internet (or other reasons) I had a backup of the installer....Plus I am a hoarder like that.. smile:D
I sitll have the very first FF1 beta and all the way up to FF606 Dec 29 build.... smile:)
Odd that it is not on that list.... smile:?:
33,857 Registered Users
+44 new in year!
13 unregistered users.
