I was going to post this is the Rendering Manager More thread but thought I would just post a new thread on this one...
Don't know if I am late to the party on this one.... smile;)
Started messing with an older filter (FF6 beta) and got the bug reporter to show so I used the latest version and narrowed down the component tree that produces the bug........
This is the filter that produces the bug....
Rend Mang Bug.ffxml
To crash FF just disconnect the Edge Detector from the bomber....The bug reporter should show up at this point.....If you just delete the edge detector instead of disconnecting the reporter does not show up, FF just locks up.......I am using Win7 x64....I am also sending a bug report.....
You could also use the Hipass or the Blend with the same results..
+1 on the Mac. After disconnecting the 3rd and last connection from the Edge Detector to Bomber+, it crashes, no bug report window though... This is Mac OS X 10.12.2.
Thank you for the report! Issue confirmed and forwarded to the devs.
The devs say the culprit is the Depth Map input of Bomber+. Other inputs and components have no effect.
Thanks GMM...
15 unregistered users.
