inujima
Max value of Sector slider of Circular Arc component had been changed in between FF5 and FF6.
So that rendering results using Circular Arc are different in two FFs even if same filters and same settings. Circular Arc Problem.ffxml |
| Posted: December 16, 2016 3:34 am | ||
inujima
| Posted: December 16, 2016 3:35 am | ||
inujima
| Posted: December 16, 2016 3:36 am | ||
+1 on the Mac. I set the attached version 5 of the filter to Sector=81, which then returns the same result as FF 6 (with Sector=90). It appears that the range of the Sector control has changed from -90 to 90 in version 5 to -100 to 100 in version 6.
Circular Arc 5.013.ffxml Math meets art meets psychedelia. |
| Posted: December 16, 2016 1:21 pm | ||
DELETE POST
| Posted: December 16, 2016 1:22 pm | ||
inujima
| Posted: December 16, 2016 3:37 pm | ||
Posts: 3507 |
Orteil should rename this filter to Amphoras
Seriously, thank you for the report, Circular Arc seems broken. That's a bug point to inujima. |
| Posted: December 20, 2016 7:21 am | ||
33,857 Registered Users
+44 new in year!
