KiwiRose
I'm sure this problem isn't with the program itself, but with windows 10, but I'm not sure how to fix it. I'm using Chrome, and I have cookies enabled. Every time I try to download a filter, I get the following:
How do I get windows (or whatever) to recognize the program?
KiwiRose
I re-installed Filter Forge on a different hard-drive, and that seemed to have done the trick. Odd, but I'll take it.
Its not Filter Forge for sure....Its the way that Windows10 handles the file associations and what Default App to use....Its most likely set to the app store for the FFXML file type....
Nicola Y.
Nicola
I have the same problem here. Does anyone has an idea how to fix the problem?
You probably need to install Filter Forge and try again.
StudioEmergenz
same Problem here
lol: you probably Need to install filter forge and try again.....
really?!?!?....
what you say..
StudioEmergenz
i installed it on an different sdd, now it works...
Peter Beckley
I just installed over the top of my existing copy and now it works. I think mine died when I did the recent Win10 major update...I think it got rid of the FFXML file link.
PayPaul
PayPaul
Firefox attempts to open up 7.0 filters using my 6.0 installation when I have 7.0 installed as well. How do I get Firefox to point to 7.0? BTW, it only opens 7.0 and downloads filters to it when my 7.0 installation is open.
Don't step on a dead dogma. It'll turn up again and bite you!
PayPaul, have you tried reinstalling FF7 ?
PayPaul
PayPaul
Why should I have to do that? I guess, in order for me to download and use FF7 filters, I'll have to have FF7 open. Anything else is a waste of my time. This sounds like either a bug in FF7 or a settings issue with the browser. Someone can do better with an explanation or a fix.
Mardar
Graphics Junkie
Filters: 61
PayPaul, The last time I had an issue exactly like this I discovered it was my firewall that had messed something up with the download. I disabled my fire wall until I reinstalled FF, then enabled my firewall again. The program worked fine after that. Give it a try.
JackMagus
This is unsatisfactory. I better not need to do this again.
LatentOmen
Yep I upgraded used PayPal and now its registered to my paypal name !I try to download new filters and it tells me to upgrade ! face it you guys screwed up and would rather make us feel its our fault and reinstall and ..... Give it a try ????
LatentOmen
Oh I did notice your page was down a few days ago ?? now everything's is a mess ???
It's the system not handling the file associations. Very typical Windows thing.
Indeed very annoying - this problem keeps surfacing here. It may be Windows "fault", but they're not going to change that.
Bookwormious
I removed Filter Forge 7 totally, rebooted my laptop and installed the plugin again. Yes, it's a pain in the - you know smile:D But it works smile:!:
