Doodle Designs
Doodle Designs
I just purchased and installed Filter Forge 6 and have two issues with Photoshop CS3.
First, whenever I start PS3 I get an error message, although PS3 appears to continue to start and run normally.
Then, once I'm in PS I go to filters but there is no FF listed.
I can see that FF is installed in my Program Files folder and that the it is also in my CS3 plugin folder in Program Files (x86).
I can start up the FF stand-alone program fine, although I have yet to try it out.
Any ideas on what is causing (and what will solve) my issues?
Windows 7 Professional (64-bit), Service Pack 1
Beth
CS3... haven't heard about this version for quite a while.
Is it 32-bit or 64-bit?
Please make sure you're not accidentally running a wrong version, for example from \Program Files (and not from \Program Files (x86).
Also, I'm afraid we can't help you with your Photoshop issue - please contact Adobe with that.
i.murphy
i.murphy
smile:D Thanks GMM for your thoughtful solution. (snicker)
Instead, for Windows you might try to download the missing driver. If it is dbghelp-xfw.dll, which seems to be the one giving lots of folks trouble, safe download at http://www.dll-download-system.com. If the site is no longer available, you'll need to look around.
After you download the "*.DLL"(file extension dll) onto your machine, copy it to Windows/System32 for a 32bit OS, or Windows/SysWOW64 for 64bit OS.
Voila! You may need to register the driver with Windows, I did not and it works fine.
Murphy Fine Arts
33,857 Registered Users
+44 new in year!
