sansttorm
Posts: 4 |
Just purchased FF6, installed it. It automatically loaded up the FF5 filter library.
Worked just fine for a few hours. However when I shut it down, then started it up a few hours later, it is loading empty. Meaning the FF6 interface loads up, but thats it- no filters, not able to open images, no nothing. Tried uninstalling/installing, still won't work. Anybody got a fix for this, or experienced the same problem? (I launched the "Filter Forge x64_exe" file as adminstrator) Platform: Windows 8.1 16GB Ram Photoshop CC2015 (won't open the FF6 plugin) Thank you Let art |
| Posted: November 20, 2016 11:23 pm | ||
sansttorm
Posts: 4 |
| Posted: November 20, 2016 11:27 pm | ||
sansttorm
Posts: 4 |
Okay, problem solved.
Read thru the forums and got this solution: >> Copied the 'Libray.Xml" and "LibraryStructure.xml" files from FF 5 >> into the directory in FF 6. Works like a cutie. Will update if anything goes wrong. Let art |
| Posted: November 21, 2016 12:53 am | ||
sansttorm
Posts: 4 |
FF 6 is beautiful.
I work with the x64 version. The speed is amazing, leagues ahead of FF 5 x32. If you were worried about slow renders, then this is what you need. -fast rendering times -smooth and quick response even in high resolution images Here's one of my digital artworks, done in FF6 using a series of filters, and later composited in Photoshop. I usually work through hundreds of filters just to get one stage of the creation process right. It takes me about six to seven stages to get one art piece done. Rendering time was about 2 minutes to 6 minutes average for every render. Thank you to the FF team. My recent digital art work: "Warmth amid Confusion" DOne using FilterForge 6 and Photoshop. Digital art by Abhie Jiwa My art site: http://www.abhieart.com/ . ![]() Let art |
| Posted: November 22, 2016 7:02 am | ||
14 unregistered users.
