G4nesha
Posts: 5 |
Hello I am trying to batch render a few pictures with the FFEasyRender but when i click the render button it says "command line not found" i tryed to copy the cmd file in the same folder than FFeasyrender but it doesnt seem to work.
Could you help me please? best regards |
| Posted: August 28, 2016 11:24 am | ||||
FFCreator
Posts: 70 |
Some things to verify fr om your site:
1 Did you use Filter Forge 4 or Filter Forge 5 (> 5.007)? If not which version of FF did you use? 2. Did you start with "New Render job"? 3. Have you "unzipped" FFEasyRender.zip in a folder of your choice (for which you don't need admin rights)? Advice : in a new folder of your documents folder. See the quick start guide in the zip file. 4. Did you install FilterForge at the default installation path? 5. Wh ere is the file FFXCmdRenderer-x86.exe situated at your system? At my system it is located at "C:\Program Files (x86)\Filter Forge 5\Bin\FFXCmdRenderer-x86.exe". |
| Posted: August 29, 2016 5:16 am | ||||
G4nesha
Posts: 5 |
Hey,
-well I am using the trial version of Filter Forge 5.010 (too new?) -I did start a nez render job yes, -yes i followed your advice and unzipped it in a folder in "my document", -no I didn't it is installed on another drive . - the FFXCmdRenderer-x86.exe file is in the Bin folder located on this other drive. |
| Posted: August 29, 2016 3:02 pm | ||||
FFCreator
Posts: 70 |
Hello G4nesha,
I am working with FF 5.010 (not demo) as well, so if the demo is the same as the licensed version, this can't be the problem. For me the program is working without a problem (FF 5.010, Windows 7 64 bit), so I need more info. 6. Which version of Windows you use 7,8, or 10?, 32 bit or 64 bit? 7. Has your user account administrator rights or limited rights? 8. Be sure that the files FFEasyRender.exe and FFEasyRenderTemplate.xml are in the same folder and are not modified. 9. FFEasyRender generates the xml file FFEasyRender.xml (same folder). After that it uses the command line renderer of FF (FFXCmdRenderer-x86.exe). Can you check with a text editor (like Notepad++) that the paths in the generated FFEasyRender.xml are correct for your system? 10 Can you use the command line renderer of FF without FFEasyRender? For more info about the commandline renderer of FF, see : Filter Forge command line renderer |
| Posted: August 30, 2016 1:47 am | ||||
G4nesha
Posts: 5 |
Hello FFCreator,
thank you for your answer 6-ok so I have Windows 7 in 64bit version , 7- I think I do ,considering the fact that I can in any folder in my computer even the "programdata" one but sometimes I am asked to whether or not let an application launch . 8-Yes they are in the same folder 9-I think they are , look "C:\Users\my name\Documents\FFEasyRenderV1\FFEasyRenderTemplate.xml" 10-the thing is that when I doubleclick on it,it opens the cmd window, and close it really quick, I even don't have time to read what it says... |
| Posted: August 30, 2016 4:05 am | ||||
FFCreator
Posts: 70 |
If the cmd windows opens and closes very fast, it seems that the FF command line renderer find errors in the (by FFEasyRender) generated xml (batch render) file (FFEasyRender.xml) or that FF command line renderer (or the shell of FFEasyRender) has no sufficient rights to open / write files or or that the FF command line renderer can't find the specified files (filters and pictures).
11 Is the behavior the same if you temporarily switch off your virus scanner(s)? 12 Please check the content of the generated FFEasyRender.xml with a text editor like Notepad or Notepad++. a Are the folder and path of the lines that start with <Result path=" and <Filter value=" correct for your system (are the files located as stated in the lines)? b If they are correct, can you attach the generated file FFEasyRender.xml in your next post? |
| Posted: August 30, 2016 6:08 am | ||||
G4nesha
Posts: 5 |
hello,
11- yes same behavior when I turn of my antivirus 12 a- yes it is properly located , see <?xml version="1.0" encoding="utf-8" ?> <Tasks> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe026.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe026_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe027.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe027_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe028.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe028_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe029.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe029_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe030.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe030_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe031.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe031_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe032.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe032_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe033.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe033_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe034.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe034_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe035.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe035_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe036.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe036_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <Task> <Image value="D:\Nikon D800\DSC_4939.Image fixe037.png"/> <Selection value="" /> <Result path="C:\Users\D\Documents\FFEasyRenderV1\FFResults\DSC_4939.Image fixe037_Library_9991-1_PR01.jpg" format="JPG" /> <Filter value="C:\Users\D\Documents\filter forge presets\Library_9991-1.ffxml" /> <Preset value="0" /> </Task> <GlobalSettings> <RenderingOptions> <UseMultithreading value="true" /> <Dither value="true" /> <Progressive value="true" /> <OptimizeBlurs value="true" /> <AntiAliasBitmapComponentSources value="false" /> <Jitter value="0" /> <TemporaryFilesLocation value="" /> <RAMUsageLimit value="60" /> <NormalMapFlipY value="false" /> </RenderingOptions> <DefaultFormat value="JPG" /> <BMP> <BitDepth value="32" /> <FlipRowOrder value="false" /> <JPG> <Quality value="98" /> <FullPrecision value="true" /> </JPG> <TIF> <FloatFormat value="false" /> <IncludeTransparency value="true" /> <ImageCompression value="LZW" /> </TIF> <TGA> <BitDepth value="32" /> <IncludeTransparency value="true" /> <FlipRowOrder value="false" /> </TGA> <PNG> <BitDepth value="16" /> <IncludeTransparency value="true" /> <ImageCompression value="BEST" /> </PNG> <EXR> <BitDepth value="32" /> <IncludeTransparency value="true" /> <ImageCompression value="PIZ" /> <FlipRowOrder value="false" /> </EXR> <PFM /> </GlobalSettings> </Tasks> |
| Posted: September 1, 2016 9:22 am | ||||
FFCreator
Posts: 70 |
The problem seems to be related to using different drives (at least on your system).
For example :
is not a valid path (if D is a drive character and not a map in C:\Users). Try if this works : 1 Copy 1 original photo of your camera in a folder at the same drive Filterforge is installed (normally the "C" drive). Suggestion : your documents folder. 2. Run FFEasyRender (new render job). |
| Posted: September 10, 2016 6:41 am | ||||
G4nesha
Posts: 5 |
Okay , so this is really annoying , I think I am gonna give up unfortunatly
, D is the name of my folder (it has the same name than my other drive, can this create a problem?) I tryed to paste the pictures in the same folder where is my FFEasyRender , but still got the same issue ... |
| Posted: September 13, 2016 5:46 pm | ||||
FFCreator
Posts: 70 |
FFEasyRender is in fact a shell for the FilterForge (FF) command line renderer. Have you verified that the command line renderer of FF (so without using FFEasyRender) is working on your system with these paths / folders? Anyway, another user asked to adapt FFEasyRender for the upcoming FF 6. With this update I will check in my code if the cause of the problem is in FFEasyRender itself. |
| Posted: September 14, 2016 4:40 am | ||||
25 unregistered users.
