ffatha
All of a sudden, the images of a lot of my presets are not getting loaded. All I get is a green color screen instead of the image. The images are loaded into a switch via color controls. Both versions 5 and 6 are doing it. It is not all the presets though.
This is a big problem because hundreds of presets of mine, constructed via certain input images, are no longer available. Have I lost them? The images are still in their original folder, of course.
Thank you!
ffatha
ffatha
Sorry guys. I had moved the directory of the original images.
Everything is working fine now and I am very happy!
I found out what directory FF was using by editing a .ffxml
file in
c:\Users\...\AppData\Roaming\Filter Forge 6\My Filters\
Thank you!
ffatha
LexArt
LexArt
i think that once you save a preset it will save the path of the external image, and if you rename or move the folder where the image may be, then FF will not be able to find it
LexArt is correct....That will cause an error in your preset or just drive you mad... smile;)
33,857 Registered Users
+44 new in year!
