okkanym
Posts: 8 |
hello everyone
Does anyone can fix this MAJOR bug on FF 4.015 it will be really sensational to have this bug fixed.. I contacted the team a while ago to report this.. also as a detail it will be lovely to have a TAB (Extended window) to FF4.015 or FF5 which will open as an extended window all the filters from library that are related to FF4.015 and to FF5 and be able to directly add them in your favorite and in the respective category as well than having FF4.015 or FF5 to be closed and open Filter librarian to transfer/export any filter from that library to FF4.015 or FF5 because there is a major bugs by importing filters from filter librarian to FF4.015 We sense this bug is also present with the version FF5 Here the step to reproduce 1 install filter forge 4.015 2 open filter forge 4.015 and close it 3 install Filter librarian 4 open filter librarian and close it 5 open filter forge4.015 and create folders in your FAVORITE 6 Close filter forge 7 Open Filter library and Transfer any Filter few or 50 and close filter librarian 8 Open Filter Forge 4 NOTICE all FILTERS are well present in Filter Forge 4.015 9 Go through any category and save few Filter of your choice in your FAVORITE and also in your folders under FAVORITE. 10 CLOSE FILTER FORGE 4.015. 11 RE OPEN filter librarian and again sel ect few filter add them to the tray and then sel ect "send to filter Forge" 4.015. CLOSE FILTER librarian 12 RE OPEN FILTER FORGE notice that all filters have been well updated 13 GO TO YOUR FAVORITE ALL FILTERS SEL ECTED AND ADDED IN FAVORITE PRIOR the step 11. ARE ABSENT/REMOVED MUST RE ADDED AGAIN AFTER EACH UPDATE. (Favorite filter save/memory is disabled in the programming or relationship link is absent) RESULT filter added in the favorite section are unable to stay in saved mode "memory" and delete themselves from the favorites library once filters have been updated/sent fr om the filter librarian to FF4.015,,, The user after having updated/sent some filters fr om the filter librarian to filter forge 4.015 and then re open filter forge 4.015 he/she has to RE locate and RE saved in the favorites section all the filters that have been saved prior that operation.. This is really delicate as the users can have saved 20 different filters fr om 20 different folders in the favorite section.. thank you for fixing this bugs for FILTER FORGE 4.015 and FF5 okkanym |
| Posted: April 25, 2016 10:10 pm | ||||||||||
okkanym
Posts: 8 |
hello everyone
Since we have posted the bug above, we have received any update in that regards and professionally it is really delicate as we are forced to download many filters ONE by ONE from the website directly to avoid to disrupt our work and all our filter research that we organized precisely in FF4.015 and especially avoiding to have all our folders in the favorite including all the filters deleted/removed. does any one in the team of FF and the developers who have created the code and the structure take this issues seriously or just to let it like that because this is far from being a pleasure and far from being a comfortable way for us to work with FF4.015 and another things we have noticed a while ago as you Transfer too many filters from the TRAY "librarian" to filter forge. then as you re opening filter forge there is a BUG kernel and we had to re install FF4.015 many moment. <class XFW::Kernel::StdException> bad allocation we have more than 100GB space available in the computer running 16gb ram and windows 7 2.20ghz. We will appreciate a great support for that bug to be fixed thank you okkanym |
| Posted: June 19, 2016 8:53 pm | ||||||||||
Posts: 3505 |
This is a known issue, we're working on it:
https://filterforge.com/forum/read.php?FID=8&TID=14171 |
| Posted: June 20, 2016 6:37 am | ||||||||||
okkanym
Posts: 8 |
Thank you GMM
we updated to the new version 4.0.16 and indeed it finally kept all the filters and the architecture of all folders and filters saved under favorites we have 2 questions. Do all the filters that are working for filter forge 4.0.16 are compatible with filter forge 6.0? such as for example My Modification Of _Soft cornered tiles for this filter we have had to ask the creator this filter to modify the code for FF4.0 as it has been taken away from the library. By copying the 'Libray.Xml" and "LibraryStructure.xml from filter forge 4.0.16 appdata > roaming> filter forge 4 > system into the FF6.0 directory will it retrieve all the folders and filters and structure filters that have been saved under favorites? the reason we asking is because we desire to buy FF6.0 and we will like to have all our filters and all folders created with all the respectives filters saved under FF4.0.16 back to FF6 without re do all the work we have done for months thank you |
| Posted: November 30, 2016 5:17 pm | ||||||||||
Posts: 3505 |
Yes. The opposite is not true, that is, you cannot open 6.0-compatible filters in 4.0
Not exactly: you need to copy two files and one folder: Library\ Library.xml LibraryStructure.xml
What are "our filters"? If you mean ones you downloaded from the online library, please copy the three items above. If you mean filters you created yourself, you need to copy the "My filters" folder.
If I remember correctly, favorites from 4.0 are not compatible with later program versions. I may be mistaken though. |
| Posted: December 1, 2016 8:30 am | ||||||||||
okkanym
Posts: 8 |
hello GMM
thank you so much for your prompt response Quote okkanym wrote: have all our filters What are "our filters"? If you mean ones you downloaded from the online library, please copy the three items above. If you mean filters you created yourself, you need to copy the "My filters" folder. Yes the filter from the online library:) ok then we will copy the the two files and the folders and also the "myfilters"as well as we saved many in these folder from the library as well. thank you for all the clarification then we can proceed to buy FF6.0 thank you. |
| Posted: December 1, 2016 4:08 pm | ||||||||||
25 unregistered users.
