When you have full rotation and also full rotation chaos, the maximum rotation is 2, yet the slave outputs an LDR value of 1.
This is intended. It is not clipped, it is wrapped back to 0: for example, with 396-degree rotation (110% of 360) the slave will give you a value of 0.1.
Why is it not wrapping back in my setup? The highlighted values of 1 are at different rotations yet are different values.
HDR mode not turned on?
I was curious about that too ThreeDee. It does make a difference and apparently what I was originally asking for was already there (no wrapping that I can see). This is strange though because should slaves only be HDR if the parent bomber is HDR? I don't think so. They should be HDR regardless because they give raw data.
No. Center X / Y and Corner X / Y can't possibly be HDR. They don't output colors per se, they output numbers represented as HDR colors. As for the Randomizer, you may need your random number in a larger range than LDR allows, because your Particle subtree could include some HDR logic. In the end, you can always convert HDR to LDR by trimming or whatever other logic is suitable in your case.
Well that's strange then because when the bomber is not in HDR mode, my rotation values are clipped at 1. What you're saying (and I agree with) is that the bomber's "HDR" mode shouldn't affect its slaves, but it does.
As it turns out, the Rotation is bugged: it is marked as LDR but it outputs HDR colors. We're fixing this right now.
33,857 Registered Users
+44 new in year!
101 unregistered users.
