Kyle
cool like a popsicle
Filters: 7
It also locks up Photoshop CC 2015 so I have to kill it via the Task Manager.
System: Windows 10
Ken1171
I am having the exact same problem, but only after installing Filter Library Backup 4.0. I get this error message:
"<class XFW::Kernel::StdException> bad allocation"
I have 16GB RAM, and still had over half of that reported as free when the program crashes with the error message above. I am also running Windows 10 x64 with all updates installed. I have tried running the program with Admin credentials, but it crashes all the same.
Please help. I bought the program but cannot start it.
Ken1171
Ok, I've figured out why Filter Forge was crashing after installing the Library Backup. It cannot allocate enough memory to index over 11,000 files at once.
I didn't see the other thead on this: https://www.filterforge.com/forum/read...&TID=13136
The easy solution is to remove half the library files from the folder, run FF, close it, add a few more files, and repeat the process until FF has indexed all 11,000+ files.
I have tried doing this in only 2 passes, but that will still crash the program. I then added the files in smaller groups and it worked. Takes longer, but it seems to be the only way to have it done.
Kyle
Filters: 7
Mine was doing it only on loading one effect when I clicked it on the FilterForge website. My image was big but only half the Pro max settings.
@Kyle: saying that something just "crashes" doesn't really help to troubleshoot the issue. Please provide detailed description of what you're doing and what error message you get.
14 unregistered users.
