This requires opening the filter in the editor. The instructions are written inside the editor using controls. Note that no overrides are activated.
What I see (is it seamlessly tiling?): As provided (noise dist. to threshold to bomber): YES Noise dist. to threshold AND to blend (any input): NO Noise dist. direct to bomber: NO Both the bomber and the noise dist. switch between seamless and not seamless (you can tell because the blobs change shape). Not a big deal, I can use the seamless tiling override fine, but strange behavior... guess that's why the override is there in the first place. Seamless Toggle Bug.ffxml |
| Posted: June 12, 2015 9:31 pm | ||
33,857 Registered Users
+44 new in year!
