KCShaw
KCShaw
I had this problem once before and it corrected itself for a short while, so I let my guard down. I have a 2048 x 2048 image from psd. I take it with the plugin into FF and choose a filter. When it renders it leaves about 1/2" edge vertical unrendered. I tried different filters same thing, I tried some different resolutions and settings within the filters same thing.
any clue ?
thanks
Please try using Filter Forge in the standalone mode.
Btw, are you applying the filter to a selection rather than to the entire image?
KCShaw
KCShaw
Hello OK reason i found this is doing this is when you have a NON cropped image that is larger then page size. I need to crop the images then I wont have a non rendered edge. I occasionally leave bits hanging off if I'm not sure i want to re-size or replace the images. I now need to crop before render.
Doesn't matter if applied to selection or entire image, does same thing in stand-alone or plug-in. Solution is to crop before rendering.
12 unregistered users.
