Circle Packing filter under construction...
The default preset takes a half second to render. However, if "Repeat" is set to more than one, or if "Size, pixels" is set to less than Max the render takes forever and/or crashes FF. Circle Packing.ffxml |
| Posted: February 17, 2015 9:16 pm | ||
I think the "Size" chain is the problem here. More than one particle may be evaluated for each output sample, and that creates an exponential sort of branching..
If you can somehow construct a parallel setup that is combined finally, it would perform much better. |
| Posted: February 18, 2015 3:36 am | ||
BTW turning off "Seamless" also causes incredible slowness.
| Posted: February 18, 2015 2:24 pm | ||
11 unregistered users.
