I don't know if this is a bug or a setting.
Anyway it is something that in my opinion should be solved. When we copy some component and we paste them in another filter, Filter Forge should copy that component or those components as they are, without messing or changing them. Instead it seems that it doesn't happen. The cases are two : 1. The components that we copy receive an input from other components not copied in our selection. This case I understand that, because some input was not included in what we copied, our copy will have some differences from what we copied, being some connections missing. This is not a problem and it is just up to our choice. 2. The components that we copy receive no input from other components not copied. This means that we copied a whole branch of the filter or the whole filter. This case it should not happen that, when we copy something, the copy is different from the copied components. The problem doesn't happen when we copy and paste something without closing the filter editor. But, because we can't edit two filters at the same time, we can't copy something from a filter to another without closing the filter editor, it would be useful that this thing was solved. Sometimes copying something even gives curious errors that appear or disappear without any clear reason ( at least not clear for me. But I'm not a programmer, so I can't say more ). Here is what I mean : ???? Group copy ???? Anyway small errors appearing in some situations aren't a particular trouble and I report them only in case FF wants to know them. Instead having a "Copy" working well also when we close the filter editor ( Attention. I don't mean "when we close FF", but simply the editor. It is clear that, if we close the program, FF should not keep record of our last copy ) would be very useful to copy part of filters, snippets, etc. from a filter to another. Otherwise, for example, what's the meaning of having snippets if, when we copy them in a filter, they lose their original characteristics? |
| Posted: November 27, 2014 1:32 am | ||
Most of the problems seem to come from Free Gradient and Profile Gradient ( but also from other components ).
If we copy a gradient from a filter to another, something seems not working in the same way anymore. Example : Extreme Pixels by Redcap I copied the whole Extreme Pixels in another filter. At a first look, the two Profile Gradients and the Tiles component gave completely different result. I thought that the copy lost its original values, instead.... everything was ok. Same values. Even if everything was the same, the result of the three components was different. To make the things easier, let's consider only the Profile Gradients. In Extreme Pixels the Repeat value was 1, but you can see many gradient bands. After copying Extreme Pixels in another filter and checking that all values correspond, the number of bands appearing in the Profile Gradient result were much less than in the original filter. Why? All the values are the same and the copy is still not connected to anything. I had to bring the Repeat value to 10 for obtaining the same result. |
| Posted: November 27, 2014 2:35 am | ||
Posts: 3505 |
Ramlyn, could you please provide a refined example filter that only shows the issue and doesn't have anything else. Our testers won't be happy to debug the entire component tree of Extreme Pixels.
| Posted: November 27, 2014 4:05 am | ||
Yes, sure.
Here is the link for the original Extreme Pixel cleaned from the areas not directly connected with strange beh * avior : Extreme Pixels ( Original ).ffxml And this is the same Extreme Pixel once copied in another filter. Also here I kept only the same areas of the previous link : Extreme Pixel ( Copy ).ffxml Below is the other case with the Bomber : Oni Grin, keeping only one group and one Bomber : Oni Grin ( Original ).ffxml And here the same group + Bomber after pasting it in Paillettes Paint : Oni Grin copied in Paillettes Paint.ffxml You can easily see how it strangely generates an error in a Bomber but no error in the other Bomber. If there was something wrong in the group, it should give error in both Bombers, not only in one. |
| Posted: November 27, 2014 10:12 am | ||
( P.S. "behavior" with that strange "*" is not my ironic comment. Ha! Ha!
It is again the forum doing something wrong ) |
| Posted: November 27, 2014 10:31 am | ||
Posts: 3505 |
Ramlyn, the tester said Size values are not consistent in your examples. If you set Size to 600 in both filters, you should get the same result.
| Posted: November 28, 2014 9:02 am | ||
Yes, the tester is right. The problem was in the "Pixel, size" value in the Result component.
Thank you very much for your help. It was very useful. |
| Posted: November 28, 2014 11:32 am | ||
35 unregistered users.
