badhomer
Hi
I recently bought and installed FF 4, and it worked fine for a few days.
Now I cannot download filters from the filter library.
When I try to download a filter (either through web, or obsolete in-program way) FF connects to the server, but then hangs on Getting the list of Filters for about a minute before giving the following message.
Initial data download failed. Reason: 'get_categories_list failed().'.
I am running Win 8 and, after I installed FF the first time, I was able to download filters with no problem (for about 3 or 4 days). Then it stopped working, and has not worked for over a week now. (As far as I know, no updates, which might have had an effect, were run on any other software on the computer between when Filter download worked and when it didn't)
I have reinstalled the program 3 times now, and have also tried it on a PC running XP. I have also tried 3 different browsers.
I have tried all the fixes suggested in the forums, and those sent to me by the support people, but still I get the error.
Any help would be useful
thanks
I am not support nor work for FF just a user and creator.. smile;) smile:)
I have had no issues with the downloads...This does happen from time to time
but a week seems like an issue on your end....When was the last time you tried it?...
I just tried it and it works fine....However you connect to the internet here is a suggestion that sometimes works....Disconnect from the net (turn off wireless/unplug network cable) altogether wait for a minute then re-connect...This actually worked for me on several occasions.....
Could also be that a firewall or other software is blocking the download....
Meshysmith
I have that problem now as well [Saturday evening 8/9/14].
I purchased FF4 a week ago and installed it on my Win 8.1 system. It worked fine and I was able to download dozens of filters and effects. However, after downloading a few more filters successfully this evening, suddenly all downloads fail with the message (Reason: 'get_family_categories_list failed'). My internet connection is working fine with other software. Trying a new 22 megabit connection did not resolve the problem.
Open to suggestions....
badhomer
Thanks for the reply CFandM. I tried what you suggested, but still no resolution.
I'm sorry to hear you have a similar issue Meshysmith but, on the other hand, it is pleasing to hear I'm am not alone. When this first started happening I was getting the same error message as you, but now mine has changed to the one I have stated above.
Valandar
I get it irregularly, myself.
Meshysmith
The problem I reported before about the 'get_family_categories_list failed' seemed to disappear and I am able to download filters now. I am not aware of anything I did to enable it; except logging in the next day and finding that it worked. I did make sure that the Filter Forge was not busy applying a filter to an image before going to the site for more filters.
12 unregistered users.
