Looks like the Particle Adapter is not working inside Groups.
When setting Size, Pixels to some non-max value, the Particle Adapter inside the Group outputs a clipped particle, just as if it had no effect at all.
Filter is attached.
Bug?
Particle Adapter Oddity.ffxml
What, no takers? smile;)
Just seen your post been kinda busy doing nothing healing from hospital stay....Don't know if its the particle adapter as much as the color control inside the group...If you notice when disconnecting the color control the particle adapter shows the FF error icon as correct in the tree....Then connecting the color control back it gets goofy again.....
Also when in the group the settings on that color control are different in handling images then outside the group....ie..."Allow Images"..."Alpha"...etc....So don't know if this could be part of it but signs are pointing to that......
Now is this a bug or just something that has not been fixed yet is the question.. smile;) smile:)
The devs said Particle Adapter works correctly but shows a wrong preview. Thanks Crapadilla, this should be fixed in the next update.
Not fixed, as of v4.013.
smile:hammer: smile;)
Appears to be fixed in FF v6.001! smile:loveff:
25 unregistered users.
