See attached image. Scrolling all the way down the list to show the last control (i.e Curve 2) is impossible, making the dialog useless for Group Components with a large number of Controls.
![]() --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 18, 2014 12:32 pm | ||
Posts: 3505 |
Could you please attach or email the filter in question?
| Posted: May 19, 2014 8:18 am | ||
Sure, here goes...
Order_of_Inputs.ffxml --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 19, 2014 10:33 am | ||
There is also a bug with sorting, specifically with send to top and send to bottom:
1. Create a Group with 30 color controls in it. 2. Name the controls from 1 to 30. This is necessary to see what's going on! 3. Set Order of Inputs to Custom. 4. Now start sorting numerically. Try using send to top and send to bottom. If your "1" isn't up top, send it to top. It will switch position with the input that was in 1st place, instead of forcing control order to cascade down. (Sorting manually by Move Up or Move Down works though). I'll spare you the naming work. Filter is attached. Try it out on the 'Unsorted' group in my filter. Also note that on the 'Sorted' group with 30 controls, control "30" isn't showing in the list when scrolling all the way down. The effect of truncating the list appears earlier (i.e. with fewer controls) if you use controls from all the different categories (possibly due to the category headings taking up slots in the list). Side-Note: I haven't tried this with the Script Input Editor... yet! Might be worth checking as well, though. ![]() 30 controls group.ffxml --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: May 20, 2014 5:41 am | ||
Posts: 3505 |
Thanks Crapadilla: we reproduced both issues, the fix will be available in the next program update.
| Posted: May 22, 2014 9:02 am | ||
| Posted: May 22, 2014 9:27 am | ||
22 unregistered users.
