CRaf
Hello,
after installing the FF 4.0 trial I added the serial key which FF did take and works, however the Filter doeesnt appear on Photoshop CS6.
I am running Windows 7 64 Bit, I did try to reinstall,uninstall and reinstall again even restarted the PC.
Help is appreciated ty
Ps: I have contacted the support team as well, no answer yet
Does Filter Forge work for you in the standalone mode?
CRaf
Hello,
yes it actually does what I have seen so far.
CRaf
Hello,
just received a message from support:
Does Filter Forge work correctly for you in the standalone mode? If yes, you can install the plugin manually:
- Create a folder named "Filter Forge 4" in the Plug-Ins\Filters folder of your PS CS6;
- Copy all the files from here "C:\Program Files (x86)\Filter Forge 4\Plugin\x64" into the folder you created.
- Run Photoshop -- Filter Forge should be there in the filter list
Filter Forge appears now in the list, going to give it a try.
Ty
CRaf
Ok tested.....
Filter appears on Photoshop but it doesn't run the application I get a bug report to send.
Contacted support, waiting for a solution.
Anyone else having the same problem?
CRaf
Ok support contacted me again, and ask me to change a value in the config file which was false to true, and now all works smile:)
Ty all
34 unregistered users.
