Top-Left to Bottom-Right looks fine. Top-Right to Bottom-Left is messed up.
*I know this effect can be achieved with the checker component, this was merely a simple example to illustrate the problem. Messed Up Diagonal.ffxml |
| Posted: December 5, 2006 2:36 am | ||
Administrator |
Yes, we first noticed this when we worked on Checker -- we added extra code to address this problem. Unfortunately, this fix can't be applied to a group of components, it can work only within a single component. Most likely, we won't be able to fix this.
| Posted: December 5, 2006 9:39 am | ||
Administrator |
All I can recommend is Anti-Aliasing with 25 samples or higher.
| Posted: December 5, 2006 9:40 am | ||
I figured out an easy workaround. All you need to do is make the white of the middle gradient 99.999 instead of 100.
| Posted: December 5, 2006 4:05 pm | ||
Administrator |
Or you can offset one of the gradients by a very small amount before the Threshold.
| Posted: December 6, 2006 1:47 am | ||
14 unregistered users.
